DVDFab Free Download
Download
How to Copy DVD with DVDFab DVD Copy?
2019-03-19 08:49:59
You have an expensive DVD and want to backup it on your hard drive or a blank DVD disc in case that it is lost or damaged, how should you do? Yes, you need a DVD backup tool. Here I recommend you DVDFab DVD Copy. It is a professional DVD copy tool with 6 copy modes to choose. Now let's have a look at the copy process.
Step 1: Choose a copy mode
Run DVDFab 11, choose “Copy” module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have 6 modes to choose. Here I take Main Movie mode as an example.
dvd copy
Step 2: Load the source
Insert a DVD disc and DVDFab will load it automatically, or you can click the “Add” button to load the source manually.
clonedvd
Step 3: Customize your DVD
After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and make advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
how to copy a dvd
dvd duplicator
Navigate to the bottom of the main interface to select a directory to save the output DVD: to select your optical drive as the directory from the drop-down list box is to save the output to a blank disc; to select a directory by clicking the "folder" icon is to save the output as a DVD folder; to select a directory by clicking the "image" icon is to save the output as an ISO image file.
 cd copy
Note:
You are not allowed to do any operations to customize your output DVD on Clone/Burn mode; on Full Disc mode, you cannot choose the titles, chapters, audio tracks and subtitles but you can make advanced settings.
If you choose to save the output to a blank disc, you will be prompted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the copy process.
For more detailed information, please visit DVDFab DVD Copy.
  • Discount
    Copy & Paste Coupon Code:
    MAMP-FAB-OFF
    When Checking out.
    Mar 25, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
