How to Rip and Convert DVD to ZUNE with DVD to ZUNE Ripper?
2017-08-03 22:32:23
Zune is a portable media player released by Microsoft in 2006. Though it was discontinued in 2011, I believe that there are still some people in the world who like using Zune to play and watch videos. If you have collected many DVD movies and you want to play the DVD movies on your Zune, what should you do? You need to convert the DVD movies into the format supported by Zune. DVDFab DVD Ripper is a good DVD to Zune Ripper which can help you rip DVD to Zune effortlessly. Now let's have a look at how to use DVDFab DVD Ripper to convert DVD to Zune.
How to Rip and Convert DVD to ZUNE with DVD to ZUNE Ripper:Step 1> Run DVDFab 10 and choose the Ripper module.
How to Rip and Convert DVD to ZUNE with DVD to ZUNE Ripper: Step 2> Insert the DVD into your optical drive, and DVDFab will load the content on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
How to Rip and Convert DVD to ZUNE with DVD to ZUNE Ripper: Step 3> Navigate to the profile library on the top left corner of the main interface and choose Device> Microsoft> Zune. There are three optimized profiles for Zune, namely Zune (Audio WMA), Zune (MP4) and Zune (WMV). You can choose the one you want.
How to Rip and Convert DVD to ZUNE with DVD to ZUNE Ripper: Step 4> Now you can choose the titles, chapters, audio tracks and subtitles, define the names of the titles by clicking corresponding tabs according to your needs.
How to Rip and Convert DVD to ZUNE with DVD to ZUNE Ripper: Step 5> Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
If you want to get more information about DVDFab DVD Ripper, please go to https://www.dvdfab.cn/dvd-ripper.htm.
