DVDFab Free Download
Download
How to Rip and Convert Blu-ray to MP4 with Blu-ray to MP4 Converter?
2019-03-06 03:40:40
MP4 is a common format that is supported by nearly all video players. So if you want to watch your Blu-ray movie on a computer without a Blu-ray optical drive or on your portable devices, you can rip the Blu-ray to MP4 to play it. DVDFab Blu-ray ripper is a powerful Blu-ray to MP4 converter, with which you can convert Blu-ray to MP4 easily and customize the MP4 video to fulfill your specific needs. Now I will show you how to convert Blu-ray to MP4 with DVDFab Blu-ray Ripper.
Step 1: Load a source
Run DVDFab 11, choose the Ripper module and load the source as instructed on the main interface.
blu-ray to mp4 converter
Step 2: Choose a format
Navigate to the profile library on the top left corner of the main interface and choose Format > Video > MP4.
Step 3: Customize your video
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, define the names of the chosen titles, and make advanced settings according to your needs. You are even able to edit the Blu-ray video with the built-in editor.
Step 4: Select a directory
Click the "Folder" button to select a directory to save the output video.
Click the "Start" button to start the ripping process.
DVDFab Blu-ray Ripper also contains many profiles preprogrammed for specific devices. For example, there are several profiles for iPad in DVDFab Blu-ray Ripper. Therefore, it is also a great Blu-ray to iPad ripper.
  • Discount
    Copy & Paste Coupon Code:
    JUTK-FAB-OFF
    When Checking out.
    Jul 1, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
