How to Burn MTS Files to DVD in 2019?
2019-03-20 00:59:40     Posted by Amanda
10148
Summary: How to burn MTS files to DVD in 2019? This article introduces you several professional DVD burners/creators and shows you how to burn or convert MTS files to DVD easily and quickly.
The MTS of AVCHD file system was popularized due to its widespread usage in camcorders with a super high resolution such as 1080i and 720p. It was specifically for large screen viewing by transferring your video clips through direct streaming or through drives plugged into the monitor or TV. However, the AVCHD files can also be burned to Blu-ray DVDs so that a traditional home DVD player can play them without any issues. This is the bottleneck as the traditional home DVD players do not support playing .mts files.
Thus, it is required to convert MTS to DVD file format. This MTS is used by every major brand starting with Sony, Panasonic, and Philips to your local non-branded device makers. This is so ubiquitous that an MTS to DVD converter is part of every video converter tool whether online or offline. However, we will list here some decent tools from the perspective of ease of use, speed and so on.
The process of conversion is super easy, and a 3 step process to be exact. First, you need to select the MTS files by either choosing something like Add or Drag & Drop feature varying from program to program. The Drag & Drop is sometimes much smoother and more convenient than browsing to the location. Second, is to do some editing or adding menu items as you might feel necessary. Third, is to start burning the DVD. This can also give some more options like burning files from MTS to DVD, or an ISO file, or a DVD media file depending on the program.
A program might also show you real-time feedback on how much of the DVD space is left, a preview of the files after the burning takes place. This can be useful in rearranging any order of playback, etc. before finally hitting the Burn or Create button. There are many options like DVDFab DVD Creator, Blu-ray Creator, open source DVD burner, online tools to burn MTS to DVD and so on.
DVDFab DVD Creator
how to burn mts files to dvd
This also has all the above options just slightly in a different way. The UI is more modern and clean and assistive. The icons are more legible and packed according to brand and presets. The DVD Creator has two presets, that is, DVD Creator and Blu-ray Creator. It ships with entire features with DVDFab 10. This allows volume control, playback mode, and much other stuff.
The under the hood enhancements include complete support and compatibility with latest Intel Core processors with Intel Quick Sync that uses its inbuilt GPU for video processing. It also supports NVIDIA cards if you have one and can leverage the GPU acceleration to speed up the processes. In essence, the DVD maker reduces the load on the CPU, speeds up the burning process by up to 30 times or more and all that without compromising with the video and audio quality of the output. And, furthermore, while you convert MTS to DVD, you can also watch movies on your laptop or browse the internet and so on without worrying about the freeze or hangs. Thus, it offers multitasking capabilities even while doing the heavy stuff.
Wondershare DVD Creator
This is a software program that lists broadly all the steps described above in a neat and orderly fashion. It does not need to convert the file formats from MTS to DVD before burning those converted files to a DVD using a burner like Nero. You can straightaway add the MTS files and start burning. This is available for free for Windows and Mac. It takes a while to convert MTS to DVD and even more if the file is too long. Also, the larger is the size of the file or higher is the quality of the file; it takes longer to burn it to a playable DVD. There are also different formats for DVDs depending on the output media file type such as MPEG-1, MPEG-2, MPEG-4 or Blu-ray H.264 encoded media files and so on. It allows you to do all the editing stuff and finally asks you to insert a single layer 4.7 GB or double layer 8.5 GB DVD to start the burning process. You cannot use Blu-ray discs for burning using this program, it seems. But, we have DVDFab Blu-ray Creator for that and that too with many other goodies.
Finally, you choose the options for DVD Folder, DVD Disc, DVD media file, or ISO and hit the Burn button. There are things like the preview, editing like tripping, cropping, changing the quality of brightness, adding subtitles, watermark, audio tracks and so on that need a lot of computing resources like memory RAM and CPU. DVDFab is a good alternative that makes use of most of your computer for those purposes.
Online Video Converter
If you wish to convert MTS to DVD online, you have to either upload and download your files or add an URL of cloud storage for your file. This is an additional step, but it might be worth if you don't want to worry about installing anything onto your system. It is hassle free that way. It's just that it is supposed to take more time. However, one has to trade something for another and therefore you can choose an alternative that suits you based on your needs.
This post introduces you how to convert MTS videos to DVDs, but if you also want to burn videos to a Blu-ray, you can have a look at how to burn a Blu-ray.
1. Convert DVDs to MP4, MKV, and etc., to watch on PCs, portable & mobile devices
2. Extract DVD audios to AAC, MP3, and etc., to listen on iPod, or other music players
3. Customize the audio & video parameters to meet specific needs from different users
4. Edit the output videos like cropping, trimming, adding text/image watermark, and etc.
You May Need Other Tools
DVDFab DVD Copy
Copy any DVD to DVD disc/folder/ISO file
DVDFab Blu-ray Copy
DVDFab Blu-ray to DVD Converter
Convert Blu-ray to DVD disc/folder/ISO file
