How to Play Blu-rays on PS4?
2019-03-19 03:57:07     Posted by Elena
10685
Summary: This article shows you how to play Blu-rays on PS4 and how to rip Blu-rays to PS4 compatible video formats for free playback on PS4.
PS4, the successor of PS3, is a powerful home video game console developed by Sony Company. In addition to playing games, it is also a great video player for users to enjoy videos or movies at home. So does PS4 play Blu-ray movie discs? With the built-in Blu-ray drive, PS4 also has the ability to play Blu-ray movies. However, there are times when PS4 cannot open Blu-ray movie discs due to the incompatibility of the disc format or region code restriction. So in this article we will show you how to play Blu-rays on PS4 and give you a perfect solution to those problems that result in Blu-ray playback failure.
Part 1: How to Play Blu-rays on PS4?
Part 2: The Perfect Solution to Blu-ray Playback Failure – Rip Blu-rays to PS4
The Blu-ray disc formats supported by PS4 are BD-ROM and BD-R/RE (BDAV, BDMV). And to play a Blu-ray movie successfully, you had better update the PS4 software to the latest version first. The PS4 system must enable the disc playback feature over the internet, so you must allow the internet connection when it’s your first time to play a Blu-ray movie disc. It is very easy to play Blu-rays on PS4, and you can simply begin by inserting a Blu-ray disc.
Step 1: Turn on PS4 and log into your account if necessary.
Step 2: Insert your Blu-ray disc to the disc tray of your PS4.
Step 3: Then the dynamic menu will pop out. And then you just need to hit the “Start” icon on the screen to play the Blu-ray disc. (You should click “Yes” to allow the internet connection)
It is certainly simple to play Blu-ray discs on PS4, but sometimes you cannot open a Blu-ray movie disc on your PS4 smoothly. Sometimes it is because the disc is an “unrecognized Disc”, sometimes it is caused by the incompatibility of the disc format, and sometimes it is resulted from the region code constraint. While there is a perfect solution to deal with all these problems you meet, and that is to rip the Blu-ray to a PS4 supported format with DVDFab Blu-ray Ripper.
DVDFab Blu-ray Ripper is the best Blu-ray to PS4 converter that can convert and rip Blu-rays to PS4 or PS4 supported video formats like MP4, AVI, MKV, and more with high quality. It even can output video files which share the same quality with the genuine Blu-ray movies. During the conversion process, DVDFab also will remove the region code protection completely. DVDFab Blu-ray Ripper also contains many advanced customization tools, and with them you are able to change the video/audio parameters, crop/trim the video, add subtitles, adjust picture values and more. The Blu-ray to PS4 converter is compatible with both Windows and Mac OS. The following are the detailed steps of ripping a Blu-ray to PS4.
Step 1: Run DVDFab 10, go to Ripper module and insert the Blu-ray disc you want to convert. DVDFab will load the Blu-ray movie automatically.
Step 2: Go to the profile library and click Device > Sony to select the PS4 as the profile. You can also click the Format tab to select a video format you want.
Step 3: Now you can customize your video according to your needs. The main movie title has been selected by default here, but you still can choose other titles. Then you can change the title name and choose the chapters, audio tracks and subtitles you want. You can also click the “wrench” icon to customize your settings and click the “editor” icon to edit the video in your way.
Step 4: Go to the bottom of the main interface and click the “folder” icon to select a directory to save the output video. Then you can click the “Start” button to start the process of ripping the Blu-ray to PS4.
When the conversion is complete, you can put the video on a USB hard drive and play it on your PS4 freely. PS4 doesn’t support 4K Ultra HD Blu-rays, so if you want to watch 4K Ultra HD Blu-rays on PS4, you can convert your 4K Ultra HD Blu-rays to PS4 supported 4K video formats.
1. Convert Blu-rays to MP4, MKV, and etc., to watch on PCs, portable & mobile devices
2. Extract Blu-ray audios to AAC, MP3, and etc., to listen on iPod, or other music players
3. Customize the audio & video parameters to meet specific needs from different users
4. Edit the output videos like cropping, trimming, adding text/image watermark, and etc.
You May Need Other Tools
DVDFab DVD Ripper
DVDFab UHD Ripper
Rip unprotected UHD Blu-rays to 4K MKV/M2TS
DVDFab Blu-ray Cinavia Removal
Remove Cinavia from the audio track of Blu-ray
